Replacement GFX Card
17 Jan 2013
Hi there, my current card (NVidia 9800GTX) that I have issues with I.e. it fails when my play A PC game, drivers are up-to-date.
I don't really really want to spend huge amounts of money but want a card at least as good as the 9800GTX, can anyone suggest a replacement around the £100 mark please?
Cheers,
Jim
Yes, though you'll get more out of your purchase with overclocking. Until a few months ago, I was using the same cpu as you; the difference in performance at stock and, in my case overclocking it to 3.4, was considerable.
Thanks for the advice.
Any other options out there sub £100?
Cheers,
Jim
This is a 'B' grade product (three months warranty), which means that something might be missing, such as a cable, or you might receive a damaged box, but the card itself will be fine.
http://www.overclockers.co.uk/showproduct.php?prodid=BG-299-GI&groupid=595&catid=683&subcat=
If you'd still prefer a brand new card, then there is this, which I 'think' is about the same speed in some games as your current card, and somewhat quicker in others.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-257-AS&groupid=701&catid=56&subcat=1983
Make sure to keep an eye on the temperature if you overclock your cpu. A program like 'Core Temp' is a good one to use.
http://www.alcpu.com/CoreTemp/
