Replacement Graphics card
8 Sep 2010
Hi guys
Recently my 980 Ti Articstorm died, i was sent a replacement but the design had changed, and thanks to the Fantastic support at OCUK i now need a new card,
How i spent £600 ish oringally i don't mind putting a little bit more to the card but the reason i purchased the Articstorm was the Design and Hyrbid sytem.
The new card ideally need to look good, have the power *will be used to demo HTC Vive* and ideally either be fully watercooled or a Hybrid card.
the 980ti Did do everything i needed i had no issues with what it can do so happy to stick with one of these.. but i am a bit fussy on how they look
Also warranty is a factor, I Got zotac for the 5 year..in the past i've had EVGA for the same.
I really need some help on this one, someone told me to hold fire to see if any Hybrid 1080's come out others have said get a 980ti as it ticks the box's and save some cash
IT wont get much use, it will be used once a week on the day i'll be running the demo day where i work thats it
Thanks in advance to any suggestions !
