Hey all, looking to replace my ageing psu (OCZ StealthXstream II 600 W), it still works but I use my pc a lot for work and its 5-6 years old so looking to protect things. Also upgrading my case to a NZXT H440 so it seems a good time to upgrade the psu too.
Looking for fully modular and the ability to upgrade my gpu to crossfire in the future. Also adding some more storage potentially.
PC specs -
i7 4770 k @ 4ghz
24gb RAM - 1866mhz
1 SSD
1 HDD
AMD 7950 (gigabyte 3gb)
5-6 case fans at low rpm.
I worked out that 650-750 Watt should do me ok but would be great to have some suggestions for a replacement!
PC specs -
i7 4770 k @ 4ghz
24gb RAM - 1866mhz
1 SSD
1 HDD
