Replacement internal power cable for Fractal Node 202
26 Sep 2010
Stoke-on-Trent
Hi all.
I don't suppose anybody knows if I could get hold of a new internal power cable for the Node 202? I'm planning a mod in this case for my next project and I may need to mod the cable so would like a spare.
Fractal just aren't answering my question and are bouncing me around.
Essentially it's just a low-profile right-angle C13, but it's a fully-molded unit and I can't find a stand-alone one without spending a fortune getting an Ncase one imported.
Cheers!
The 202 has a C13 to C14 extension inside because the PSU is internal in the top-right if the case. It uses a low-profile C13 though because the PSU is a tight fit.
Pretty much the same as what's in a Ncase only longer.
Try cablemonkey.co.uk You could make one, I'm sure the connectors would be available and would only need a bit of mains cable.
Andi.
