Replacement laptop screens?
Caporegime
17 Jul 2010
My son decided to see how strong the screen surround on his laptop is, cracked it and now although it boots the screen is ruined.
So I find some replacement screens on the Worlds favourite auction site and they're all £35-£45. Now I thought the screen was half the price of the laptop in the past, and obviously these are cheap Chinese knock offs but has anyone bought one? A genuine Dell screen will likely be hundreds, will one of these last at all? It's a relatively low res screen from a Dell Inspiron Q15R (I think, it's at his mums), 1366x768 I'm sure.
No such thing as a genuine dell screen. They all come with LG Philips, Samsung, Au Optronics etc. The stuff you see pm ebay is what are in them from factory.
I would advise taking the old one apart before you order a new panel so you can see the hidden part numbers and what and where the connectors are. This gives you much greater confidence that you are buying a matching replacement, ask the seller if necessary and provide the info. These non-Dell replacements work fine.
