Replacement LG TV Stand Body/Bracket
18 Feb 2006
Hi all,
Odd one - my LG TV (LG 42LN575V) is mounted on the wall and thinking of moving it downstairs and back onto its original stand. Problem.. I have the stand base, however I cannot seem to find the stand body (the bit the base mounts on before screwing into the TV).
Anyone know how I might be able to replace this, or if there is something universal i can maybe use?
See below the stand, and the bit missing;
https://i.imgur.com/ckQTxWG.jpg
I'm missing the top section of this stand.
Otherwise I guess i'll just keep the TV we have (wanted to put the Smart TV downstairs to utilise NowTV/Netflix/Plex/Amazon instead of any other boxes/units).
Hi
You can buy a universal table top tv stand from the jungle for around £30 or if you want the original part them do a search for part no: 3628298PM on partmaster.co.uk.
Hi all,
go on the bay and search your model and the word guide youll find what you need
Thanks all.
Think for the price for now I might just get a universal stand, will be £20'ish cheaper than buying the bracket I need. Can always look into this later.
