Possibly bit of an obscure thread
But the left shift key on my black MacBook has fallen off.
I've never even used that key, but the piece of plastic that goes into the left metal "hook" appears to have sheared off, although there is no sign of it.
And I picked my MacBook up and it just fell off
I found one website in America, but they don't sell the shift keys.
So does anyone know where I can get a replacement?
In the UK ideally, apple engineers won't order you one in unless you pay them to install it, which is a minimum one hour job
Hopefully you'll be able to help me out.
Cheers
Cheers
so damn worth it!
