Replacement motherboard, same as before. Reinstall Windows?
V_R
V_R
17 Jan 2007
UK
Hi all,
My Asus P5B Deluxe died and i got a new replacement. A like for like RMA, same one again, but it looks like it may be a new revision of the board maybe. (1.10 i think) Sorry i am at work at the mo so cant check.
So i rebuilt everything back into the case just as it was, same hardware, just a new board.
Was all geared up to reinstall the os but it just booted up as normal, so i had a play and it seems to be working just fine played a game, ran a benchmark all seems good.
So should i still do a fresh install? Do i need to do a fresh install?
What do you think? :)
Obviously doing a fresh install would be the "right" thing to do just to ease any potential problems, but if it works then I personally wouldnt bother.
If it's exactly the same except for the revision then as there's no major hardware diffs there's no real reason for doing a re-install.
I personally wouldn't do a re-install if I was happy with the state of the current install.
My thoughts exactly, The current install was only a week old before the board died so it wouldn't be a major hassle, just rather not.
I'll keep an eye on it to see if all is ok, if it behaves itself then i leave it as it is.
Thanks guys.
:cool:
