my dvd burner on my laptop is playing up and dying a slow death so am looking to replace it so am just wondering if the ones on ocuk site are all standard sizes or would i need a specific one for a toshiba laptop, the best spec the better
) front panels/face plates. Some manufacturers laptop drives have more "shaped" fronts (such as a corner cut out) to cater for styling or to accomodate more connectors on the laptop. You may be able to transfer this if you get a drive model of the same make the laptop is already using. It does mean you may have to undo some small screws to change the panel though.so really the best bet for me is to take out the old one and take it from therecheers
Looks pretty much like the one I have. 2.5' SATA interface.
