replacement osd software for netbooks
3 Dec 2002
Groovin' @ the disco
hi,
just got myself a netbook and the osd software that comes with it displays the most fowl icons, is there any generic software that can be used instead?
Thanks
My telepathy isn't working so well, unfortunately you're going to have to tell us what netbook it is, what OS it's running and if you are trying to change the icons or the theme.
