Replacement phone
23 Aug 2005
Beds
My SE W850i was recently stolen - the insurance company have offered the Nokia 6288 as replacement. Is this a good deal or should I hold out for the W850i?
Thanks in advance.
Thanks guys - the insurance company have appointed someone to replace the phone - they're saying that they have no stock of the 850. Is there any other phone I should ask for?
I was in the same position a couple of years ago, and insisted on the money instead.
After a couple of telephone conversations with supervisors, a cheque arrived within a week - enough to buy the replacement elsewhere and have some money over. :)
If you can't do as Rambaud suggested, you could try for the W610i or maybe even the W880i.
I assume you use the phone more for music rather than the camera (being a W-series). Otherwise, maybe the K550i/K800i: the latter being the higher spec one and therefore more expensive.
Jon
/Edit: My inability to type :rolleyes: :D
W580i would be a reasonable replacement, or you could push for something like the S500i (slider phone for slider phone please!) ;)
The W580i and S500i are almost exactly the same phone (in the same way the K750i and W800i are).
The differences are Walkman software on the W580, plus a pedometer and TrackID, and a couple of other bits.
Hardware is exactly the same.
Might be worth pushing for the K810i, but they are considerably more expensive than the K800i (I have no idea why).
Jon
/Edit: My typing's appalling this evening
