replacement power brick (xbox 360)
12 Oct 2009
Can anyone suggest a good place via trust, as to where I can get a replacement power brick for my Xbox 360?
I'm afraid I can't tell what rating the rail is as my xbox isn't in it's original shell, but my power brick says Output 175watt 14.2A, although I have been using my mate's brick which is Output 203watt 16.5A
Only reason I am after a new one is cos my mate has just got his xbox replaced (had the 3 red lights) and needs his brick back and mine doesn't work as I have additional led lighting within my xbox.
eBay is your best bet as Nismo has said. Loads of them on there.
You need either the 175W PSU again, or you could just as easily get a 203W and it will work. I would err towards getting the lower wattage unit purely because it will be newer and more reliable.
