Hi, folks.
Was just after a little advise with power cables. I need to replace my PSU Kettle Lead cable for a longer one, so I can move my tower. Trouble is there's lots out there that don't specify the gauge. This is the model here - http://www2.seasonic.com/product/platinum-1000/
I know most will work fine and be all good with the correct fuse in anyway (Will just switch fuses when I grab one) Anyone able to recommend a cable that would be suitable. Looking for 2.5-3m
Or any advice at all would be great.
Cheers
Cheers
