21 Mar 2015 at 11:07 #1 mS_Design mS_Design Associate Joined 15 Aug 2012 Posts 21 Hi guys, Does anyone know if its possible to buy a power cable for any or specifically a Silverstone Zues 1350W PSU? I moved house and it didn't come with me! Cheers!
21 Mar 2015 at 11:45 #2 Bickaxe Bickaxe Soldato Joined 8 Nov 2013 Posts 8,931 Location In the pub Pretty sure any kettle lead will do, unless that PSU has a specially designed version. http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-GE&groupid=1929&catid=153
21 Mar 2015 at 11:46 #3 MagicBoy MagicBoy Soldato Joined 18 Oct 2002 Posts 19,353 Location South Manchester .. Last edited: 21 Mar 2015
21 Mar 2015 at 11:47 #4 Akagi Akagi Caporegime Joined 29 Jul 2011 Posts 36,608 Location In acme's chair. That PSU doesn't use a standard kettle lead you doofuses. <3 I doubt this thread would be here if it did. You need a C19 IEC power cord with a nice big fuse - http://www.overclockers.co.uk/showproduct.php?prodid=CB-104-OK Last edited: 21 Mar 2015
21 Mar 2015 at 14:41 #5 Bickaxe Bickaxe Soldato Joined 8 Nov 2013 Posts 8,931 Location In the pub I looked at the PSU and thought something didn't look right but couldn't place it.
21 Mar 2015 at 14:51 #6 MagicBoy MagicBoy Soldato Joined 18 Oct 2002 Posts 19,353 Location South Manchester That's the same connector as the old PowerMac G5 Quad, it's suitable for a higher current draw. The normal connectors would be fine in the UK. I guess they're going with that one as the amperage is higher in 110V countries.
21 Mar 2015 at 15:17 #7 sastusbulbas sastusbulbas Associate Joined 26 May 2008 Posts 1,777 Standard 16amp cable, a few quid. Some of my Powerblocks and amps used them too. As pointed out by Acme.
21 Mar 2015 at 17:04 #8 mS_Design mS_Design Associate OP Joined 15 Aug 2012 Posts 21 Acme said: That PSU doesn't use a standard kettle lead you doofuses. <3 I doubt this thread would be here if it did. You need a C19 IEC power cord with a nice big fuse - http://www.overclockers.co.uk/showproduct.php?prodid=CB-104-OK Click to expand... This is precisely the correct connector. Thanks for the responses guys!
23 Mar 2015 at 09:17 #9 dhallam dhallam Associate Joined 30 Sep 2009 Posts 103 Location Long Bennington Good God we use those on our server UPS units
