Replacement PSU dilemma for 210V
10 Mar 2004
Oxford
I have a Biostar 210V & the PSU has just blown. I have found one site selling an official Biostar replacement for about £50 but i am just wondering could i put an uprated PSU in from another manufacturer as i have found them cheaper else where. Or would every1 advise me to stick to Biostar's own replacement parts.
if you can get a higher rated one then go for that
just be sure to check the dimensions are the same or at least v.similar and there isnt any special bracket or special shape or anything on the biostar ones causing other makes not to fit properly etc
