Replacement PSU modular cables
30 Jul 2007
Surrey
So I've bought a second hand GTX680 Lightning which requires 2x 8pin connections compared to my old GTX460s which required 2x 6pins.
I cannot for the life of me find the 8pin PCI-E cables for my powersupply and cannot seem to find them to buy online either - I can only seem to find extenstion cables.
My powersupply is:
Silverstone ST750F (fully modular)
Any recommendations?
Looking at the silverstone product page: http://www.silverstonetek.com/product.php?pid=240
It mentions it does come with 2 x 6+2 Pin PCI-E cables..
1 x 24 / 20-Pin motherboard connector(550mm)
1 x 8 / 4-Pin EPS / ATX 12V connector(750mm)
1 x 8 / 4-Pin EPS / ATX 12V connector(550mm)
2 x 8/6-Pin PCIE connector(550mm)
2 x 6-Pin PCIE connector(550mm)
6 x SATA connector(500mm / 250mm / 250mm)
6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm)
2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
They take a look around your cable bag.
