Hi
I built the below system about 4 years ago, with one exception, I used a Corsair HX520W PSU that I already had, which I've just checked and actually dates back to 2008!
The system has been generally great for what I wanted and needed. But recently it's started to randomly immediately shut down, especially if the sun is shining on the case as it does late afternoon. Takes a knock on the side of the case to get it to fire up again. Suggestion from Electrical Engineer son is that it's most probably a dry solder joint in the PSU.
Given the PSU is now 15 years, probably due a change. I'm happy to consider either a direct replacement or to upgrade it for something better and with a bit of future proofing.
Recommendations for a replacement please?
My basket at Overclockers UK:
- 1 x MSI B450M Mortar MAX (Socket AM4) DDR4 mATX Motherboard= £92.99
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £179.99
- 1 x Zotac GeForce GTX 1660 SUPER Twin Fan 6144MB GDDR5 PCI-Express Graphics Card= £218.99
- 1 x Crucial Ballistix Sport LT BLS8G4D32AESBK 3200 MHz, DDR4, DRAM= £79.99
- 1 x Sabrent 1TB Rocket NVMe PCIe M.2 2280 Internal SSD= £109.99
- 1 x WD 3TB Blue 5400rpm 64MB Cache Internal Hard Drive (WD30EZRZ)= £84.95
- 1 x Corsair CX-M Series 550W 80 Plus Bronze Semi Modular Power Supply (CP-9020102-UK)= £73.99
- 1 x Kolink Citadel Micro-ATX Case - Black= £39.95
