Replacement psu
7 Jan 2005
Nottingham
I have a tagan 580w easy con and now i have watercooling it is one of the last things that is makeing quite a bit of noise.What psu are decent dont make hardley any noise. What will i get second hand value for my psu.
only prob i got wid none modular ones is trying to get the cables out the way because even with the mod one i got now there aint nuf room
Seasonic will have a modular one out at some point in the future, called M12.
Until then you have to choose between silence and modular.
You should take a look at the psu section over at spcr to see whats the next best thing to seasonic.
Well Tagens are meant to be the best modular PSU's, Seasonic, Enermax and FSP have the top most reliablility, but Seasonic are out ahead of it all again because it's the most silent :)
