Permabanned
- 15 Dec 2008
Right guys, I have an HWLabs GTX 360 Extreme and a HWLabs 360 X-flow.
They're very restrictive and means that I have to use 2 pumps.. I've been through loads of combo and currently have in posession:
1x Laing DDC 10w
2x Laing DDC 18w
2x Laing D5's
1x Koolance PMP500
The average 360mm radiator has a pressure drop between 0.15-0.25psi
These HWLabs radiators are ~1psi each!
This is killing my flow rate, I could run 2 pumps but that takes more space then I ideally want.
So I thought the best option was just to replace the HWLab radiators with some that aren't as flow restrictive and just run the one pump on PWM.
So what radiators should I replace them with? I've been looking at the XSPC radiators as they seem to perform well and are some of the least restrictive around.
1x Laing DDC 10w
2x Laing DDC 18w
2x Laing D5's
1x Koolance PMP500
