Replacement recommendations
27 Jan 2009
Oxfordshire
My AOC 2367M is giving up sadly, right 1/4 has picked up image ghosting. It happend a while back and turning off then back on fixed it but it's just not going away this time out.
So, might as well upgrade in the process. Have an AMD R290, considering 1440 will be worthwhile and maybe even freesync cost depending. Mostly used for gaming and movies. Budget would ideal top out in the £250-£300 area, but points are awarded for costing less. This Iiyama did get my interest however I hear the TN panel is not so great(?) and cannot find any reviews online.
If the monitor is right, 1080 is till fine by me.
