Replacement Relays
7 Feb 2004
North East
I need to replace some relays.
Wehrle 54 201 101
2/4 x 21W
12V
12V 30A
86 87a 87
85 30
Pictures of each - https://imgur.com/a/LLmZ5w5
The originals would be 25+ years old, so while I can easily find some still available just by googling the model numbers, I'm a little stuck on these 2 relays.
Can anyone confirm the relays I've linked are suitable replacements, or suggest part/model numbers of reputable brands?
Searching for the Wehrle relay it seems it's a 3 pin flasher relay. I can find a load of these from generic brands and the below is commonly suggested. I'm not using LED lights, but this is top of my list so far - https://www.classiccarleds.co.uk/pr...relay-for-classic-cars-with-oe-clicking-sound
I've also found a Hella option, which I'm less certain about compatibility.
https://www.ebay.co.uk/itm/146405395145
https://www.autodoc.co.uk/hella/936419
The second looks to be a modern unbranded replacement for whatever would have been there originally. I can find a Halfords own brand that looks like it would do the job.
Any advice appreciated :)
