Replacement rift controller
wnb
wnb
27 Feb 2004
The trigger on one of the controllers is a bit dicky, had a look at the oculus website and at £70 it was a bit of an eye opener. Anyone know of an alternative place to buy or get mine repaired.
I suspect the bay or similar is the most likely place. Cex also sell them. But then if you're going down the replacement route it might as well be worth taking yours apart and see if there's anything obviously wrong with it.
Rift CV1 or Quest/Rift S? If Quest/Rift S it's in warranty.
I have looked at a tear down and due to my failing eyesight it's easier said than done.
