- 20 Aug 2007
- Solihull
Hey guys, I am currently looking to replace the wireless router at my workplace, I know I shouldn't really link other tech sites but I don't know how else to show it... XD
https://www.google.co.uk/search?q=b...pw.r_qf.&fp=5283461a5d78853d&biw=1366&bih=653
That is the router we currently use, it uses an RJ-45 internet cable in, straight from the office blocks modem, but at the moment, the router is constantly failing and we can't get into the admin settings, and without a linux based system, resetting the lost password is apparently impossible so my MD has asked me to just replace it.
As far as I can tell, the router takes internet straight from a modem(in the comms room, not directly in our office), the another single RJ-45 is routed straight from the first "Pc out" (1) socket, and then disappears back into the floor. From here I can only guess that this cable that disappears, goes to a switch/hub under the floor of our office somewhere, where it splits between our server running Microsoft SBS 2008 and then splits between the other workstations on the network.
As you can probably guess, all I am looking for is a strong router that will handle everything the current one can, but be very fast, stable and have great signal for wireless devices in the office, (laptops, ipads, iphones etc)
I was looking at this one, (my MD asked for the biggest and the best router I could get) any opinions, advice?
http://www.overclockers.co.uk/showproduct.php?prodid=NW-059-AS&groupid=46&catid=1596&subcat=
Thanks in advance,
Jamie
Thanks in advance,
Jamie
seems best choice for our leased line internet + switch/hub setup
