Raikiri said:Whata re you using to measure temps? If it is coretemp then you're fine up to about 70c, I would only start to get worried then myself. Only HS that would fair better would be the Tuniq Tower or Titan Amanda, I don't think a faster fan would do that much.
Worth a try though I suppose![]()
