Replacement seal for EK-Quantum Kinetic TBE 200 D5 PWM D-RGB Pump / Reservoir Combo
21 Jun 2006
UK
Does anyone know where I can get a replacement seal for my EK-Quantum Kinetic TBE 200 D5 PWM D-RGB Pump / Reservoir Combo?
I've sprung a slow leak from between my pump and res, i've tried removing the res, cleaning and tighening after reassembly but i cant seem to get rid of the leak.
It's still under warranty but last time I had some spares from EK they took an age to come so dont mind buying if i can get one sooner.
OCUK sell spare seals for the fittings, so I would give them a call and see if they have the res seal, but don’t advertise it on line.
Saying that, EKWB don’t list the seal of their spares page on the online shop.
I think you may be waiting for EKWB to send you one, so I would launch that process ASAP.
I found the part on EK's website.
Its only £1.99 but shipping is nearly £15 which is a bit hefty.
Presumeably you now know the size so check Ebay. O-rings are very cheap on there and that's where I had to get mine for my EK CPU and GPU blocks when EK's support was useless. I won't touch EK ever again after all that hassle.
