Replacement silent components needed for existing build
1 Nov 2013
Hello all,
After much testing i've finally configured my Define R4 case for 2 x exhaust (rear and top) and 3 x intake (2 front and 1 bottom) - all running ~600 RPM
My PSU is the loudest component at idle.
My GPU, PSU then CPU is the loudest under gaming load (in that order)
I currently have an XFX 850W Bronze PSU and an EVO 212.
I'm looking for a ~700w silent high quality PSU to replace the XFX PSU and a replacement for the Hyper EVO 212, the only condition is that they must reduce noise significantly.
What options do i have for an AIO for the GPU? (1080 Ti ordered and due April) i want this system as silent as possible without impacting performance - 4.4Ghz 4770k overclock and i will be overclocking the GPU.
Help!
Thanks guys. (System monitor info of 15 mins gaming in GTA V then 15 mins at idle on current fan config)
