Replacement sky q hub router?
22 Aug 2008
Hi all,
Can anyone recommend a combined router/modem to replace my current sky q hub router (old 3 lights upright version). We are currently getting fftc and connection has been great but with various devices in house we are finding our WiFi is not very good. Apple devices have very poor connection for some reason. We have a steady 74mbs download and 18 upload. Want something better for connections we can just swap the hub out for, preferably WiFi 6 if pos! Must also be able to connect up to our existing sky Q system. Price range under £100?
Thanks.
Hi all,
Thanks.
If you're mostly happy with the Sky Q router you can get them pretty cheap (~£10-20) off second hand off ebay/amazon IIRC
I currently have a sky Q router, just the old type. Do you mean the newer sr203 version? I did look at asking for a newer sky max hub from them but it seems if you have more than one sky Q multi room box they will not offer it due to a connection mesh problem.
I recently got them to send out a new router and got the SR203 version and I have two mini boxes working fine with SkyQ and the router
