I have a Asus Rampage V Extreme
My graphics cards are in the No 1 and No 3 slots, and I am currently using the ribbon SLi cable that came with my mother board.
I have tried fitting the 3 way SLi (Cos it'll look neater) that come also with the board, but have come up against a problem. The fans case of my top card catches on what would be the middle card socket.
If I was to buy one of the ROG 3 way SLi bridges (L) can it be configured as just 2 way removing the middle connections all together? Or can you suggest another option.
A friend suggested removing the middle connections on the three way that I have, can this be done. Will it work?
