Hi all,
Basically I'm pretty sure the motherboard in my wife's PC has died, it's an X99 system with a 5820k and 4x4GB@2400MHz. Basically it refuses to even POST, no error codes or anything not even the fans spin up, I've tried swapping memory/storage/PSU/GPU and no luck so it's either the CPU or the motherboard, I'm leaning towards the motherboard.
Whilst the system is getting on a bit it's still a 6 core CPU and holds up perfectly fine performance wise for what she needs, so it seems a shame to replace the CPU and have to buy a new CPU water block as well as the motherboard (CPU is under a custom loop as it was my last main gaming pc).
Has anybody got an experience of any of these suspect looking Chinese X99 motherboards that seem to be readily available? Doesn't need any fancy features, just the ability to take 4 ram sticks and an M.2 Drive. Another option would be to go an auction site and buy something used from one of the more well known western brands, but that seems like it might be a gamble as as well.
failing that the other option would be to cut my losses and buy into a modern platform but it's going to be the more expensive route.
