Replacement Xfire Card
Status
Not open for further replies.
26 Aug 2012
North West
Got a replacement Sapphire Dual X 7970 card for a faulty one.
With new one in system, I don't get an option to enable Xfire. ALso GPU-Z results are funny.
Also replacement Card, even though same model number and box e.t.c it has 2 8 pin connectors where as my other one and the one it replaced has 8+6 pin. The replacement says 8 + 6 pin connector should is perfectly acceptable. The OCUK description says it should have 8+6 pin as-well.
Any help please?
Status
