- 10 Mar 2005
Hi
Would the Corsair H50-1 High-Performance CPU Watercooler be a suitable replacement for the cpu fan that comes with the Phenom Quad 955 black edition? (I'm finding it rather noisy now in the warmer weather
I have this inside a Cooler Master Sileo 500 case, will the corsair fit ok into this?
Or could you recommend a quieter alternative to my stock cpu fan anyway ?
Cheers
Chris
)I have this inside a Cooler Master Sileo 500 case, will the corsair fit ok into this?
Cheers
Chris
