Replacing 21" CRT monitor, help needed
31 May 2011
I'm currently using a ADI G1000 "21" CRT, so desk space is not an issue :) and I can't decide on a monitor.
I want a widescreen monitor with a native resolution of 1920X1020 because of possible performance issues. I use my pc for gaming (FPS, RPG) , movies, music editing.
are the 120Hz screens better on your eyes because I'm susceptible to eye strain. I like the idea of getting the Iiyama Prolite B2712HDS 27" (£279.98).
or
OcUK 24" TRUE HD LED Monitor (£134.39)
liyama Prolite E2473hds 24" widescreen LED Monitor (£179.99)
ACER GD245HQ 23.6" 120Hz 3D Widescreen LED (£229.99)
Benq XL2410T 24" TRUE 120Hz 3d Widescreen LED Monitor (£281.99)
Any help would be greatly appreciated.
System specs,
Win 7 64-bit
AMD phenom II X4 965
4GB Corsair XMS3 DDR3 1600MHz
ATI Radeon HD 6850 1GB
Samsung 1TB SATA-II
M4A88TD-V EVO/USB3
Thanks for the replies:)
Can you recommend a model with an adjustable stand, something like Liyama Prolite B2409HDS 24" (£173.99) or Liyama Prolite E2473HDS 24" (£167.99), are the specs good.
The OcUK 24" TRUE HD LED Monitor (£134.39) and the iyama Prolite E2473hds 24" widescreen LED Monitor (£179.99) are the same monitor
^ Yes. If you are coming from a CRT due to the smoothness (CSS player?) then you might want to consider 120Hz.
