The 92mm stock fan on the coolermaster hyper tx-3 doesn't really shift much air. I know I should probably just buy a better CPU cooler but can't be bothered with removing motherboard. What is the best 92mm fan, no budget or noise restriction just the best 92mm fan which pushes the most air possible.
