- 22 Nov 2023
- UK
Hello
I am trying to replace old mechanic Honeywell thermostat for what the manufacturer says is a universal Honeywell DT90E and should be suitable for all boilers. However after swapping the stats, DT90E did not communicate with the boiler and I had to swap back to the old stat. The manual states that DT90E is either 24V or 230V. Therefore I just left the DT90E connected to the 24V connection on PCB board as it was with the old stat, please open the link: https://drive.google.com/file/d/1VF8SHWkA6Et-bOvm_1psXnU82OBj1Jr2/view?usp=sharing. Yellow circled is the white "24V terminal" connection. Sadly for some reason there is no communication between the DT90E the boiler, with this connection. Thinking about wiring it to 230V terminal right next to it, encircled in green. Now I am not sure which terminals on brown, 230V box to use. On the 24V both wires are connected to two RT terminals. But on 230V there is only one RTterminal. Does that mean I have to use L and N terminals? Any ideas why is it not working on 24V? The Boiler is Thema Condens F30E if that helps. Thank you very much for your help and wisdom...
. What do you mean by "Are you able to identify those two wires at your stat position?"
