- 16 Nov 2003
- On the pale blue dot
So my oven is on the blink, it doesn't hit the requested temperature, and putting it up to max it takes forever to get there. It's a cheapo 'comes with the house' oven and I've been wanting to swap it out eventually, but the question is how. Here's what it looks like:
The whole unit is sitting on legs, I can't seem to take off the wood panel below the oven to see what's in there. Underneath all I can see is the slack from the electric cable (electric oven, no gas supply in the room). If I open the oven door there are screws on either side that I guess will allow me to slide the whole unit out.
Is it as simple as buying a replacement unit? I really don't want to have to start replacing the kitchen cabinets. Could I go full height? Note the air grille on the panel I pulled off, what's it for?
Is this something that's easy to replace or should I be paying for install?
