Replacing a fan
12 Sep 2005
Grundisburgh
My Thermaltake case has a 200mm exhaust fan on top. I want to install two hypbrid coolers for my two GTX680's, the only place the rads and fans will go is where the top fan is. Do you think I can do that on the basis that the heat will be generated at the radiators and not inside the case? so I won't need the exhaust fan.
The CPU is currently cooled by a Corsair Hydro system.
Andi.
