Replacing a faulty gtx 480 oc
29 Jul 2003
Help!
My cards on its way out.
When i bought it it was a bit of overkill for my system which is a q6600.
Im after something with similar spec (don't mind being a bit less) without the heat and power consumption and it can't be bigger than the 10.5" of the 480
Anyone any ideas what to go for.
First; What is your price range?
For the green team, the GTX 660 offers slightly better performance while taking up a smaller footprint, requiring less power and running cooler.
For the red team, the Radeon 7850 performs similarly, better under certain conditions, but worse under others.
These are cards which perform similarly though, If you're going to upgrade, you'd obviously be better going for something better within your price range.
