- 12 Feb 2006
- Surrey
the head on my network cable broke on the bit that you press to unclip it and what clips it in which is annoying as the cable keeps coming out of the pc. I have anothedr head but i have n clue how you put it on and how easy it will be.
Do i need some tool for this or is it a simple sqeeze and open the just click close?
im worried though as i need the net, its my life, and if i was to make a mistake i would have to wait 3 weeks for my step dad to come home from hols and fix it. So if i was to attempt this whats the chances it screw it up, like put the cable in wrong?
thanks all
(i put this here is ai thought the people on network section would probably only know just setting up networks rather then electrical stuff, feel free to move though)
thanks all
) and have a go at it, search google for cat5 wiriing diagram or just look at the other end of the cable and make sure your colours are in the same order as the working end
