I have a 750W no-brand PSU, which isn't as terribly crummy as some of the no brand units, it's been running for years fine and is SLI capable but the fan is by far the noisiest part of the system despite (from a hand over the vents) shifting about as much air as my Fractal 120mm fans.
The fan is supposed to be 135mm but it is actually 140mm x 25mm upon measurement. The CFM isn't labelled on it but I think so long as I get a reasonably powerful 140mm fan it should be fine.
The rated current is a bit higher than most fans I've looked at, can anyone recommend me a suitable fan?
+ I know to avoid the capacitors
