Replacing AIO fans
5 Nov 2014
Hello All,
I have the Antec H1200 Kuhler 240mm AIO Liquid Cooler and one of the fans is making a horrible noise when the PC is turned on. (link below)
https://www.overclockers.co.uk/antec-h1200-pro-kuhler-240mm-aio-liquid-cooler-hs-014-an.html
I would like to replace both the fans, does anyone have any suggestions at all?
I have been looking at these
https://www.overclockers.co.uk/noctua-nf-p12-redux-1300rpm-pwm-fan-120mm-fg-07c-nc.html
I have the NZXT Source 340 Midi-Tower Case with the rad mounted at the front of the case and then the fans mounted to the rad pulling air in to the case.
Thanks for the reply, ill take a look at them.
Its strange as the the issue only happens for the first few mins and then stops and is fine till its turned off again.
Probably because when the pc boots it is spinning full speed then the speed control kicks in. Would replace as it sounds like the bearing could be on its last leg
Probably because when the pc boots it is spinning full speed then the speed control kicks in. Would replace as it should the bearing could be on its last leg
Yeah, going to replace them both to save having to do the other down the line.
