Following a leak from the existing waste outlet on our bathroom basin, I successfully managed to destroy the existing fitting by over tightening the centre pin in an effort to stop the leak. (Lesson learned).
I am looking for a suitable replacement and am not really sure with regards to sizes.
The original fitting had a 40mm trap connected to it directly by way of a compression type fitting, and itself measures 40mm. All existing waste pipe is 40mm. All the basin waste kits I can find online so far are 32mm?
I know I can convert 32mm to 40mm,but is it likely that a 32mm basin waste is going to be too small for my basin?
' measures 62mm in diameter.
