Replacing Case Fans
3 Apr 2006
Scotland
My old Lian-Li PC-7 came with 4 x 80mm fans.
1 has had the blue spark of death. (fiddling with the maching running is never a good idea....wasted a optical drive at the same time :eek: )
1 occasionally decides to sound like its chewing up bits of the case.
1 also occasionally goes mental and has a missing rivet on the guard.
Anyone able recommend some 80mm fans?
Do you get fan mounts when you buy fans?
Thanks for any info! :)
yate loon, nexus & s-flex are what you should look at, quiet, reliable and the specs aren't overrated.
Don't get akasas, they are pathetic overpriced junk. (120,80 & 92mm tried)
Thanks for the replies.
I don't think ocuk do any of the above fans. S-flex at 120, but I'm after 80mm.
When you buy the fans, do you also get bits to mount it to the case?
Are AcoustiFan any good?
Yes you do get the screws to mount the fan to the case, AcoustiFan are quite good fans, if a bit overpriced.
OcUK isnt the only online shop in the whole world, they are stocked at other places, not saying any more on that matter though.
