Replacing coolant
10 Nov 2010
West London
I've been running my first watercooling system for two years now without any issues. I am going to upgrade the graphics card (water cooled) so I may as well change the coolant at the same time. I'd appreciate some advice as to whether I need to flush out the existing coolant/debris before putting in new stuff?
I have a Zalman Reservator XT and I used their coolant (mixed with distilled water). It was blue then, but now it is pretty much clear. Other XT users have experienced blue deposits in their system so I am worried there may be some of this lurking within. So perhaps it would be a good idea to flush it, but if so what do I use? Is ordinary tap water OK? I live in West London and the water here is pretty hard. If not tap water, what do people recommend?
Any advice gratefully received
John
Problem with the Zalman kit is that I'm not sure if its a mixture of Aluminium and copper parts or just all Alu. In which case I would get some deionised water from Halfrauds for £3 for 5 litres. Then do a hot water flush with tap water, followed by a few flushes with Deionised before refilling with the Zalman stuff again. Reason I say that is that their liquid is probably designed for the dissimilar metals in their loops.
You are right, there are a mix of metals. The Reserator XT is Aluminium, the CPU block is copper base and Aluminium cover and the GPU block is also Aluminium. Their fluid is for a mix of metals:
Anti-Corrosion Coolant (ZM-G300)
This coolant contains a high quality anti-corrosion agent for various materials including copper, aluminum, plastic, and other metals that prevents corrosion for long term operation.
- Materials : Propylene Glycol & Anti-Corrosion Agent
- Weight : 250ml
- Freezing Point : -9℃
- Exchange Cycle : 1 year
However I am planning on using Eco-Earth from Fluid XP+, which is Aluminium safe and non-conductive/corrosive + bio-degradable.
I like the idea of using hot water to flush the system. If there is any blue gunk hopefully that'll shift it.
Cheers
John
drain you coolent into a large bottle and then use a coffee filter in a funnel and pour into another bottle cheaper to reuse your coolant than buy new, filter catches all the gunk that might have built up in your coolant
well when i add any new block i renew all the tubes strip any blocks im going to reuse and slap them in the dish washer did this with my rads as well gets them well clean
i clean the internals of my rads buy fitting a hose connector to the hot tap on the bath and just run the tap for 5 mins flushes all the crap out of them word of warning thou those rads will be well hot after mins of hot water going through them
