Replacing cpu need to remove motherboard?
You can do yes. Some may find it easier doing it on a more open surface so you can make sure the CPU is alligned correctly. But if your case has decent space around it you should be fine.
My case has plenty of space around the cpu, Are the old push pin coolers easy to get off? its been about 5 years since i put a pc together and that was only the 2nd one i had ever built lol
