- 28 Feb 2007
Hello all,
Can anyone on here shed some light on a standard procedure for replacing the front coil springs on a fiesta (2002-2008) or any car......
I presume it is:
Jack up car
Take wheel off
support suspension arm thing and jack up a small amount
clamp the spring
Undo bolt holding the shock absorber and remove it
replace spring
reverse of above
Seems pretty straight forward to me, the only unknown is the removal of the shock absorber
I presume it is:
Jack up car
Take wheel off
clamp the spring
replace spring
reverse of above
