Replacing g9 laser
31 Jul 2009
Behind You
I bought this some years back at a local computer shop, they had loads of boxes of them for £20 a throw with the weights, casings and everything, I was only in there to pick up a generic mouse while deciding on a proper one and I ended up forgetting about it :) (their regular mice were 15 quid.. looking back its no wonder they are just another "gadget" store now)
So after some years of solid service I need to replace this, the sensors on the buttons are on their way out and its become quite noticable on the side, I'd sooner not bring about RSI from pressing too hard :)
Budget (-£20) more if its a close match
Something simular in shape/form
5 button layout (2 top, wheel clicker, 2 on side or simular)
Wired / Optical
Not bothered about programmable/dpi switchers, can do without them just fine (else budget would be higher)
Even then I'd go for a direct replacement if that were the case as theres new g9's floating about still (fleabay and so on) as its a discontinued product
Just seeing if theres anything simular on here.. I know the two in the £17 price range (gigabyte and coolermaster) ocuk sell are close
