replacing gfx card, best way to install?
29 Jun 2004
getting rid of my gtx260 sli and putting in a gtx560.
There was a process on here of how to uninstall the gfx drivers, i think you had to go into safe mode, then uninstall? it worked last time, only i cant remember all the steps.
any help would be great,
thnks
Personally id just pull out the GTX260, install new card, install new drivers if you dont have the latest ones and the jobs a good un :)
the drivers are exactly the same for the 206 and 560. so just reinstall over the existing drivers you reckon
Yep, no need to bother with driver sweeper or safe mode theese days, just perform a clean install when installing the new drivers after youve fitted the new card.
