Replacing GPU stupid question
16 Jun 2013
I have only just realised I haven't cleaned my loop in about 21 months :eek:.
The fluid still appears to be clear so would I be good to just empty it, fit new GPU and refill or should I really be flushing the loop out?
I haven't noticed any increases in temps so I would assume the thermal paste on CPU is still good. Is it worth replacing it regardless?
If I replace something I always strip everything down and give it a good clean and/or flush. Fresh thermal paste wouldn't hurt either.
Once drained you'll be able to see how much build up / discolouring your tubing has, if your on flexi for the amount 3m cost I'd potentially look at new tubing.
Thank you for all the answers.
Surprisingly all of it looked almost brand new. Would have thought I'd see some corrosion or discolouration of the metals.
Clear fluid coloured tubes ftw :D.
Had forgotten how much of a nightmare this is to bleed :(. Buggering about with bits of plastic to redirect the air bubbles :D.
5 hours no leaks. 33 on CPU and 28 on GPU(32 100% usage). Quite happy with that!
