Hi,
New member looking for advice.
I've got a Cambridge Azur 640H music server, which is basically a glorifed PC based on a Epia 1000M ITX motherboard, and I think runs a cut down version of some Windows operating system. The server froze up over the weekend and when I took the cover of I found that the CPU heatsink fan was loose (one of the pushpins had broken) and also the fan wasn't working. So I guess the CPU must have overheated. I did try refixing the heatsink and got the fan working, but no joy with the server.
I've manage to buy an identical replacement motherboard and am just wondering whether I'll have any issue in getting the server up and running again.
Luckily I have a disc from Cambridge which alows a fresh install of the operating system (which I used last year when the Hard drive failed); this worked fine - BUT I was just wondering if there is anything I'd need to do first with a new motherboard before trying the fresh install process again. I can't imagine I could just replace the MB without needing to do a fresh install, although obviously I'll see what happens first.
Any comments would be appreciated.
Thanks
Alchad
Thanks
Alchad
