Replacing jack and wire.
15 Feb 2013
Edinburgh
Hey, I'm needing to replace the jack and wire for my headset
It's come clean off :p
I was wondering if there's any pointers for the wire, it appears to be some kind of thread/wire twist,
the wire itself is very thin, seems to need heat to burn off whatever coating it's got on it.
Am I good to buy more of this and solder it to the old stuff?
Should I open the headset up and replace the whole length with a new piece?
Thanks in advance.
Probably your best bet as it will have more cores than normal headphone cable because of the microphone.
It's a razer megalodon, it's pretty damp broke atm
I was planning on splitting the cable out and putting the different speakers into the different jack slots on the surround
Possibly, I'm just going by what the wiring suggests in the maelstrom unit
It has a digital ground,led,mic,analogue ground, and 4 speakers (2 left, 2 right) listed at the terminus of the cable, written on the pcb
But if there's only 2 that'll be far easier
Going by the images on google its 1 driver per side but doesn't look like an easy job redoing the wire fully :S
